1997–2005 Buick Century Owners: Common Repairs, Maintenance Logs & Mileage Reports
ede smith
Century
Calling All 1997–2005 Buick Century Owners!
I thought it would be interesting to hear what other folks have repaired, replaced, or still need to fix on their Century.
Please comment below with:
  • Your model year
  • Current mileage
  • A list of repairs you've done or plan to do
I'll go first. Here's my update:
2001 Century – 160,000 miles
Midwest / Rust Belt
🔧 Brakes​
  • Rotors: Replaced at least twice — due again due to condition, even though not below discard thickness.
  • Pads: Replaced 3 times, last time was pad slap.
  • Rear Drums:
    • Replaced leaking wheel cylinders
    • Believe I also did shoes and hardware at around 50K
  • Brake Line:Replaced one section (passenger side to ABS module).
    • Planning to install this copper-nickel tubing kit before winter:
      3/16
  • E-brake cable: Snapped. Not sure I’ll replace it.
  • Brake Fluid: flushed when doing rear cylinders and front brake line.
🚗 Steering/Suspension​
  • Wheel Bearings (front): Both replaced
  • Outer Tie Rods: Replaced
  • Sway Bar Links & Bushings:Replaced
    • Pinch weld failed — welded back instead of dropping the subframe and entirely replacing sway bar
  • Alignment: One done so far
🌡️ Cooling System​
  • Radiator:Replaced
    • Also replaced coolant temp sensor (tough to reach behind the radiator)
    • Still chasing low coolant warning
  • Water Pump: Replaced 3 times
    • Last time probably unnecessary — leak was front timing cover gasket
  • Gaskets:
    • Intake upper and lower manifold gasket(common on 3.1 engines)
      • Tech replaced thermostat and flushed coolant at the same time. One job I sourced out.
      • two of the injectors he had problems removing, brittle plastic, and they were replaced.
      • valve covers
    • Front timing cover gasketwas leaking
      • I replaced last fall
❄️ AC​
  • Still running on original charge
  • Noticed metal shavings near the compressor clutch last fall
🛞 Power Steering​
  • Was groaning on turns
    • Cleaned vent cap
    • Replaced some fluid after siphoning old stuff out
⚙️ Engine Sensors​
  • EVAP purge valve: Replaced (emissions code)
  • IAC valve: Cleaned — huge improvement for idle
  • Throttle body / MAF: Cleaned (MAF cleaned every air filter change)
🔌 Electrical/Ignition​
  • Plugs and wires once
  • Alternator: Replaced twice
  • Serpentine Belt: Replaced 2–3 times
  • Starter: Replaced (AutoZone brand, occasionally sounds off)
  • Instrument Cluster: Re-soldered as mileage indicator was no longer lit.
  • Driver side window motor
  • Right rear window regulator
  • Trunk Harness: Wires were pinched — spliced and soldered
⛽ Fuel System/Exhaust​
  • Fuel Pump:Bosch replacement
    • Left rear seat out since repair — don’t miss it
    • Crimped the harness (may upgrade to Klein ratcheting crimper)
    • Learned crimping is better than soldering for vehicle wiring
  • Fuel Filter: Replaced at least once — caused leak from rusty fittings
  • Fuel Line:Replaced a small section by the filter
    • Hard to bend due to tight radius
    • Shop said they smelled fuel — I haven’t noticed anything since
  • Exhaust pipe
    • Welded hanger back on near Cat
🔧 Still needs work​
  • Lower Control Arms:
    • Bushings are bad, and ball joints are original
    • Planning to replace entire control arms
    • Not impressed with RockAuto options — leaning toward Mevotech Supreme as Moog RK models are not supposed to be very good.
  • Struts/Springs:
    • Still original
    • Aftermarket quick-struts don’t seem great — haven’t pulled the trigger yet
  • Tires:
    • Junkyard Pirellis — still have like new tread but are 10 years old
    • Need to be replaced but difficult to find decent 205/70/15
  • Calipers/Hoses:
    • Still original — thinking about replacing.
  • Transmission Service:
    • Fluid has never been changed
    • Planning a drain-and-fill(no flush)
      • Replacing filter, gasket
      • Capacity: ~7.4 quarts (no converter)
      • Will do 1–2 more fluid changes later to cycle in fresh fluid
  • Cooling System:
    • Hose Clamps: Replacing worm-drive clamps with constant-tension types. This could be the source from what I am smelling.
  • Electrical:
    • Door lock actuator is sticking on front passenger door. I haven't heard great things about aftermarket ones.
  • Body Control Module Issue:
    • Strange intermittent dashboard lights
    • Removed piezo siren from BCM, haven't resolved issue though
    • More details here
  • Fuel Line:
    • Would like to replace more (or all), but unsure where to start
  • Piston Slap:
    • Happens in cold weather — disappears once warm
That’s where I’m at for now. I’m sure I’m forgetting a few things, but my goal is to get past 200k miles and beyond.
Now it’s your turn — post your Century’s:
  • Year
  • Current mileage
  • Repairs done / planned
👇 Let’s keep these old W-Bodies going!
I have to replace my Fuel Pressure Regulator next as I have fuel in the vacuum line and hard starting.
I asked AI common problems for the 2001Century and this was the reply (it looks like it highlighted my problems with the lower control arm/ frame/ wear):
Here is a complete, mechanic-level list of the most common problems on a 2001 Buick Century (3.1L 3100 V6 / W-body).
This includes engine, cooling, transmission, suspension, electrical, HVAC, steering, body, fuel, and brake issues.
This is based on known long-term patterns of the 3100 engine and the W-body platform, not recent news, so no web search is needed.
1. Upper & Lower Intake Manifold Gasket Failure (coolant leaks)
  • Most common problem on the 3100 V6.
  • Causes coolant loss, overheating, chocolate-milk oil, misfires, or hydrolock.
  • Often leaks internally first.
2. Coolant Elbow Leaks
  • Plastic elbows between tensioner and intake crack.
  • Sudden coolant loss.
3. Piston Slap (cold start knock)
  • Light knocking for 10–60 seconds when cold.
  • Usually harmless and normal for this engine.
4. Idle Air Control (IAC) valve sticking
  • Causes rough idle, stalling at stops, erratic idle, or hard start.
5. Mass Airflow Sensor (MAF) failure
  • Causes hesitation, poor acceleration, rich mixture, poor fuel economy.
6. Fuel Pressure Regulator (FPR) leaking into vacuum line
  • Floods engine → hard starting until pedal is pressed.
  • Very common on these cars.
7. Cracked vacuum lines
  • Causes lean codes (P0171), high idle, poor drivability.
8. EGR valve issues
  • EGR passages carbon up → rough idle, stalling after decel.
9. Crankshaft Position Sensor
  • Causes intermittent no-start or stalls at random.
10. Oil leaks
Common leak points:
  • intake manifold
  • valve covers
  • rear main (less common)
11. Radiator leaks at plastic end tanks
12. Heater core clogging
  • Weak heat or fluctuating heater output.
13. Water pump failure
  • Belt squeal + coolant drip under pulley.
14. Pressure control solenoid (PCS) failure
  • Harsh 1–2 / 2–3 shifts
  • “Bang” into gear
  • No codes sometimes
15. TCC (torque converter clutch) solenoid failure
  • Shudder at 45–55 mph
  • Stalls at stop after driving highway speed
  • P0741 often appears
16. Shift actuator issues / worn valve body
  • Delayed shifting or slipping.
17. Transmission pan leaks
  • Common with age and softening gasket.
18. Lower control arm bushings (very common failure)
  • Causes clunking, wandering, uneven braking feel.
  • Worn bushings can elongate subframe mounting holes over time.
19. Ball joint wear
  • Clunks over bumps, sloppy steering.
20. Outer tie rod ends
  • Play + alignment drift.
21. Sway bar links & bushings
  • Rattling over bumps.
22. Struts worn
  • Nose dive, poor ride quality, floaty handling.
23. Power steering pressure hose leaks
  • One of the most common leaks on this car.
24. Intermediate steering shaft “clunk”
  • Felt in steering wheel when turning.
25. Blower motor resistor failure
  • Only high speed works (very common GM issue).
26. Window regulator failures
  • Power windows fall or get stuck.
27. Ignition switch electrical portion
  • Car can fail to start or accessories cut out.
28. Instrument cluster issues
  • Intermittent gauges, dimming backlights.
29. BCM (Body Control Module) glitches
  • Weird behaviors: door locks clicking, lights acting odd.
30. Blend door actuator failure
  • Stuck on hot or cold, clicking from dash.
31. A/C compressor clutch failure
  • No engagement or intermittent cooling.
32. ABS wheel speed sensors failing
  • Causes intermittent ABS light; usually front.
  • “Service Traction” or “ABS Disabled” message.
33. Brake lines rusting
  • Common on older W-body cars in rust-belt climates.
34. Front caliper slide pins sticking
  • Uneven brake pad wear.
35. Fuel pump failure (in-tank)
  • Long crank, whining from tank, sudden no-start.
36. Fuel lines rust
  • Especially near rear wheel well region.
37. Rear door latch / handle failures
38. Weatherstripping shrinkage
  • Wind noise at highway speeds.
39. Rust at rear wheel arches (common in northern states)
40. Alternator failure
  • Not as common as some other GM models, but still a known issue.
