Spriteman
- Apr 14, 2013
- Central Florida
- 1998 Buick Park Avenue - Base - 132K Miles
Decided to do my trans fluid and filter this weekend. Here's a link to a few pics - https://plus.google.com/photos/1181...s/6108064692490459217?authkey=CIz30YzTs_HOugE
I started by removing as much fluid as I could through the filler tube via HF hand pump - filled up a gallon oil jug to the top - so I'm guessing that was right at 5 quarts. Then I loosened and removed the front and side bolts on the trans pan following the FSM instructions - then tapped the pan bottom with a rubber mallet. Loosened the back bolts and allowed the pan to drop an inch or so in the front allowing the rest of the fluid to drain out. Removed the back bolts and lowered the pan cover.
With 105K miles on the 1998 BPA I don't think the fluid or filter was ever changed. It was dark dark red but did not smell burnt and I had no trans issues I just wanted to get ahead of any problems.
There was a small amount of grey silt on the top side of the filter but there was no sign of metallic material - also there was no metallics on the magnet - I'm thinking that's a good thing.
During refill I put back in right at 7 quarts which is what the FSM says a filter change should take.
My only problem was when I was remounting the cover - I had all 20 bolts attached to finger tight and started tightening with torque wrench to 12 ft/lbs per the FSM. I was using my new torque wrench and the bolts just kept tightening and I knew that I was going past 12 ft/lbs. Finally, I broke off one of the bolts in the trans case - luckily there are enough bolts to allow for a good seal without one.
After that I just tightened up the rest of the bolts to what I felt would be a good torque by hand and left it at that. Anyone have any suggestions for removing the broken bolt and ordering a new one. The thread hole goes all of the way through the case - I can feel the other end of the bolt above.
Other than that the change went well - hope the pics are informative and helpful.
