My daughter's 2000 Lesabre sputters after cold start when in reverse or drive. It's fine after it heats up. We bought the car 2 years ago and I replaced an aftermarket fuel pump to fix the gas gauge issue. I also went ahead and replaced the fuel filter. That was over a year ago. The past 3 or 4 months this issue popped up. Recently I started throwing parts at the problem. The car is almost 24 years old so I figured it wouldn't hurt to replace them. I replaced the MAF, IAC and the Fuel pressure regulator. I also replaced the shrader valve on the fuel rail. Yesterday, I removed the MAF sensor and sprayed some throttle body cleaner in the Throttle Body. I also cleaned that little sensor attached to the big main air
intake hose. Before replacing all that stuff, I sprayed a little bit of Carb Cleaner around areas of the vacuum lines. The engine didn't rev up or down anywhere. I'm going to change the shrader valve again today. Maybe I got a cheapo one and the seals are bad. I'm also going to inspect the hole it comes from. Maybe I left a small amount of broken gasket in there or something. If you can let me know if anyone has had similar issues.
