bobby49
- Jul 5, 2016
- Buick
The 3.8L engine has 159K miles and runs normally. When started, the coolant temperature starts to climb normally until it hits equilibrium at 183F. This isn't quite right, and it should be about 197F, because that is the thermostat rating. The thermostat was replaced, and that had no effect. The coolant stays around 183F until I get to a long steep uphill. Then the coolant climbs to 216-221F, and this seems abnormally high. The air conditioner is off, naturally. Once past the uphill, the coolant slowly returns to normal around 183F. There are no coolant leaks, steam, or smells.
It was suggested to me to purge any air bubbles from the cooling system, so I removed the radiator cap and let it run up to equilibrium. I cycled the A/C and the heater. No bubbles or smells. This is a normal Dex-Cool mixture in use.
Now what? It doesn't seem like a water pump problem or a thermostat problem.
