2004 lesabre limited battery location
rcl153
Can anyone tell me where the battey is and how do you access it? Also ,how do you jump start the car? Thanks!
The battery is under the rear seat on this particular car. You can jump it from there, or the positive terminal junction under the hood. Of course, ground the negative (-) jumper cable to a good engine metal surface.
Thanks for answering.Do you have to go to the dealer for a battery,or can you get one at the auto parts store?I read about the vents. What brands can you use?
If you have an Advanced Auto in your area, they have the vented version of this battery. You can have them install it for no additional charge if you prefer. Click Here
Battery is vented to outside of vehicle.; Installation may take up to 30 minutes. Battery located under rear seat. Vent tube connections should go under the side terminals to reach the venting system.; OE Spec: OE Group 100; OE CCA 770; Battery Spec: 770 CCA, Maximum Starting Power in any Climate, PowerFrame Grid Technology
AutoZone also offers a vented battery for this model. Click Here
Part Number: 78-AGM
Warranty: 3 YR
Notes: Warranty consists of 3 years free replacement. ***750 Cold cranking Amps***. Battery gasses need to be vented to outside. Battery located under the rear seat.
