Dan Hoover
- Mar 1, 2017
- Buick
Wife's car left her stranded for first time. I found a crank-no spark-coils check ok,no codes though,seen this on my previous car-thought "cps". Trailered the unit 2hrs home picking up a CPS(the ugly one in the back side of the block). Checked the car again at home-same.
Changed cps-no change-checked wiring and sure enough an open connection at the sensor end. Repair the fault, now car has spark and 50psi fuel pressure will start and run a few (3?)seconds and die.
Did a key relearn-no dice. Did a resistor bypass-no change,verified the security by intentionally altering the R value-yes tdm locks the car out. So removed bat cables for a day, checked the injectors for a short- none found-seem all same around 24 ohms. did the security relearn and back to square one, Start-run 3seconds die. The car will run indefinitely on starter fluid sprayed into the intake so it is definitely fuel cut off. Wish I had a real scan tool but that is not the case. Nearly lost my patience with this one.Any suggestions would be greatly appreciated. Gut feeling is bad bcm, please tell me I'm wrong.
(much of the diagnostic procedure was thanks to threads on this site-thanks for all the good information, I learned a lot)
