So recently I have noticed that my transmission is slipping more often. It mostly happens when I go reverse to drive and first will slip a bit then catch hard. Once in a while after taking a turn it also has a minor slip after getting out of second gear I believe.
Have anyone else had issues with this before? I just want to know if I may be on the verge of having it fail. I recently had a transmission flush a thousand miles or so ago because of this issue but it is up to 150,000 miles so is this a common thing for this vehicle because of the heavy weight of it?
Thanks in advance.
Thanks in advance.
