GAEV23D49J
Hi All!
I'm new here and first of all, I'd like to send the best wishes to this nice community.
I've inherited the Enclave 2009 that hasn't any move since 2017 year. I've changed the battery and try to start. The engine has run, no strange noises, the transmission also works fine. But when I'm trotting above 1500-2000 rpm the engine has stopped suddenly. No check engine light. I've had no fault codes via the OBD scanner.
So, I've checked most of the important data via OBD and found that the vacuum value is too low. For example, on idle it is near -100 and after throttling it is rising to zero and even above zero!
All oxygen sensors are OK. The entire intake tract is clean. No oil inside the MAF sensor and the throttle is also clean.
Please help me sort out with this problem.
Thanks in advance.
Thanks in advance.
