G
G-926422
Does anyone know of a tool that can remove the pcv valve without breaking it?
that tool is for the hose removal not the valve itselfThis is a Cheap Tool that can be used to Remove the Hose from the PVC : Fuel Line and A/C Quick Disconnect Tool
I watched a Video on Youtube where the Guy Cut one of these in half, put a Half on each side of the Tube and then
Pushed them both into the Connector on the PVC to Release the Tube.
Here's the Video: PVC Hose Replacement
With the PCV valve, does it just yank out? I'm afraid to pull on it.To me, it looks like that Bolt was Drilled.
But I don't think it was, just an odd looking bolt.
I found one that looks similar, but the head isn't rounded.
Just wondering why you're trying to remove that Bolt?
I've pointed an Arrow towards the PCV in your photo below.
I reposted the Picture Sam14GS posted earlier in this post showing the PCV.
His picture is from above, the PCV is between two of the Coil Packs.
