MCBuick24
 - Jul 29, 2025
 - 2018 Buick LaCrosse
Just curious if your LaCrosse is still fixed after you replaced the serial gateway module? My 2018 LaCrosse is doing the same thing and already did new wheel bearings, gas pedal position sensor and reflashed the power steering module at the local Buick dealer but problem still persists. My local Buick service manager who worked as a mechanic for the dealership doesn't think there's a high probability that will correct my car's problem. They want to replace the rack and pinion because they believe the power steering control module (which is built into the rack and pinion) is defective. Appreciate any helpIn case anyone needs this information, I finally narrowed the issue down to the "serial gateway module" this module acts like a router for the other modules so it plays a big part in communications, I replaced the part myself $57.00 the problem is you have to disassemble a lot of the dash to replace this part it sits behind the radio ! I took the car to the Buick dealership and had it programmed for $99.00 the car has run flawless for a month now I believe this time its fixed for good 👍
