'92 Roadmaster crazy idle
Rhia504
Laurinburg, NC
1992 Roadmaster Limited
My roadmaster cranks up cuts off, then cranks and will run idle from 2-10 on tachometer. Then when cooland temp gets close to first line it levels out for about 5 minutes. Then it idles low again each time the tachometer drops the oil pressure also drops with it. Reading 0 oil pressure then 50 as the tachometer raises. I have changed the IAC, CTS, TPS, full tune up plugs, wires, oil, oil filter, and coolant. What could it be?
