Adam Ressler
- Jan 8, 2015
- 1996 Roadmaster Collectors Wagon
I have a 1994 Buick Roadmaster Limted Sedan with the Lt1. I have a few things to fix, but I need some information on how to fix it. First is a squeak squeak from the pulley area, I've noticed that a pulley seems to have a slight wiggle when running. This pulley has the flat side of the belt around it, its mounted under the alternator, possibly power steering? Second is the drivers side mirror, the glass is all cracked up and top assembly is lopsided. How do I go on removing it? Third is the trunk pull down motor, where is it and what are common causes for it to fail? Thank you for your time and knowledge.
