bbresse
- Dec 4, 2012
- Buick
i have a 97 riviera with a multiple cylinder misfire. found out the last time the plugs were changed over 150k miles. i got the new wires and plugs and everything was going fine until i went to do the plug and wire and cylinder 6.
since the engine is mounted sideways the 6th cylinder is against the firewall and is only accessible on one side. i tried to twist and pull the plug off like i did with the others but it wasn't budging since i had no leverage.
i then tried pliers and again not much leverage so nothing came of it. like i said i have new wires so ruining the boot on there isn't a big deal.
i read somewhere that cutting it off is also an option if you're replacing it, so i tried that but with the metal sheathing over it i can't really get all of it out. i looked at the other sheathings and it won't be able to slide over the boot at all until it's out.
i know they make a spark plug wire pliers but i really don't think those will do anything since it's almost impossible to get anything on the boot at all nevermind get any means of leverage once you do.
any suggestions? i really need to fix this as fast as possible.
