Patmark
- Sep 25, 2015
- Buick
Just picked this up. 200k miles, dirt cheap. Billy Joe Jimbob had worked on it prior to purchase. The sunroof would open to vent, then stall. Seller said "she might leak a bit". Have had no rain since I got it. Tore out headliner, which was 3 separate levels of Hell. Popped motor, which runs nonstop in one direction, goes a from 12 to 3 o'clock on the wheel the limiter switch runs on, then shuts off. Took glass out, trolley was popped loose on one side. Maybe I knocked it out. Trying to sync roof motor. Found one breakdown that says to get trolley lined up as if the glass was flush, then align trolley pin with 4th rib in the bracket. This thing is off by almost 2 inches, if I am looking at the right pin. Is it the lower pin with a black plastic roller on it, or the one that is molded as part of a spacer that faces inward? What's most frustrating is that I subscribed to the Alldata deal that gives you the actual GM service information. While I was checking fuses popped the back seat, which was soaked underneath. When pulling headliner found a broken drain line.
I freely admit that I have never had occasion to mess with a sunroof. But felt comfortable with my overall skill level to tackle this.
Thanks for your time.
Pat
Pat
