G
G-843783
this fix the issue?Wow! I have a new scanner and was using the menu button for everything. Pressed different Live Data button and there was a ton of info.
Engine temp was between 207 degrees when accelerating aggressively often and dropped to 187 degrees when parked/idling.
Interestingly, I saw that the intake air temp sensor 2 is reading 32 degrees even though it's 73 degrees outside. I am going to try and find a new sensor and replace it.
How do you think this would impact the cooling fans and/or air conditioning system?
