Did a search and found this thread. Did not want to start a new one unless I should?
My friends car has the C0040 code, and 0245 code. I changed the front drivers side bearing (needed it anyways but noticed the entire connect was gummed up and other 3 are clean) and the codes went away then came back once we started driving.
I did some reading and tested the other 3 abs sensors. All were around 1100 ohms. Unless they can still be faulty, the issue must lie either in the connector on one of them, or a wire running back is broken right?
I did look up that 0245 and it pointed to the EBCM. I don't want to know what a dealership would charge for that, but i did hear about absfixer(.com) that will do cheap repairs.
I am unable to find the wiring pinout and layout of where I need to trace these wires to to check for connectivity. Can anyone help me and give me some pointers on what else to look at?
My car clubs scanner does read abs, but it tells me 0040 is a rear sensor on the scanner. However, most google search results say front right???
Thanks
