Active suspension
FYI for those looking for active suspension.
Front struts: right - 13319742
left-13319741
Rear shocks: right - 13319758
left- 22834093
Would those work for a 2014 Regal GS? I've had the hardest time finding the correct parts. I switched them out, and now the car sits about and inch and a half higher.
Did you switch the springs from the original GS struts to the new struts? If not, you will not be able to reproduce the GS lower ride height.
I did a loaded strut. How can I reproduce the original GS ride height? That space in the wheel well is driving me nuts..
You need the original springs. Try salvage yards.
Can I order oe springs that will do the job? I’ve been looking, but can’t get a straight, concise answer. Part #s perhaps?
Maybe coil-overs?
If you can find them. They typically are adjustable.
So, if I were to take it to the dealership, they wouldn’t be able to correct this issue? I’m at my wits end.
A dealer isn't going to install a coil over suspension. Either live with it or find used springs at a salvage yard. Car-parts.com might help.
I’m seeing a lot of 2013 GS’s on car-parts.com, not many 14’s. Will the struts and springs from a 13 work/bring my desired, “stock GS” ride height on my 14?
C
check with a GM dealer if the same part was used
