Ziggy
Member/PA owner since 2008
- Sep 27, 2008
- Buick Park Avenue 91 base
Wear and oxydation of contacts and switches can cause a leak in current that can drain your battery. The bulb in question may appear to be off, but there still can be a current flowing, not enough to light the bulb but in the end it can still drain the battery.
It would have to be connected to that 60a batt1 fuse, you have to disconnect everything that is connected to that one by one and in the end you will find it.
