yes it only says lost communication with tcmHave you used a scan tool?
u0101What is the code?
yes when i turn the bright lights on the voltage increases to 13.8 up to 14.1 , and yes i got it checked at autozoneDo you ever get voltage readings higher than 12.5?
Have you used a handheld voltmeter to test alternator output?
the car stopped working after coming from the store, battery was completely dead and starter was making a loud noise when trying to start it. so we got a new battery and starter and the car started working again. thing is before the car stopped working and we changed the parts it did not have any problems with the tcm losing connection or headlights blowing out randomly. sometimes the backup camera and trunk button won’t work when the tcm acts upWho decided you needed a new battery, alternator and starter, you or a shop?
Why the alternator?the car stopped working after coming from the store, battery was completely dead and starter was making a loud noise when trying to start it. so we got a new battery and starter and the car started working again. thing is before the car stopped working and we changed the parts it did not have any problems with the tcm losing connection or headlights blowing out randomly. sometimes the backup camera and trunk button won’t work when the tcm acts up
we changed the alternator because the alternator was supposedly overcharging so i thought the voltage regulator went bad. voltage was at 15.5 after we put the new battery and starter in and stayed in the high range around 15.1Why the alternator?
It appears something is not right with the parts or the installation of them caused an issue. Check the battery cables for corrosion possibly under the insulation.
Why the alternator?
