rbell2915
- Dec 29, 2019
- 2012 Regal GS 6MT
1992 Riviera 206K miles. Intermittent complete loss of all electrical power. Everything will flick off then back on in a fraction of a second as if you pulled the key from the ignition. ABS, seat belt, SRS lights go through their routines as if I just started the engine, as I'm going down the road. The radio also turns off then on but does not lose time or memory. I have checked the battery terminals and cleaned and checked the fusible links at the distribution center by the coolant tank. I have wiggled and tugged on the harness that runs from the distribution center. No change. Leaning toward ignition switch but there is no problem starting, it starts and runs perfectly until it starts this intermittent problem. Anyone else experience this? If ignition switch where can I find one? Searching Amazon, AutoZone, Napa, etc come up empty. Do other cars use this same switch?
