mitchflorida
Active Member
- May 22, 2016
- South Florida
- 2016 Summit White Regal, Premium II, Moonroof, Driver Confidence Package
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
I am surprised you didn't go for the K&N air filter. Are they too much of a bother? They add about 5 HP, I think. | ||||
A K&N air filter don't seem to filter as well as a paper filter. Plus if it's over oiled the oil can contaminate the MAF sensor. So a 5hp gain isn't worth all that.
FYI, the foam pre-filter is designed for cold climates and protects the paper pleats from getting clogged by the snow and ice that might get through the air intake. For very dusty areas it might protect against large particles that might otherwise get through, but how many people will clean the foam liner?
In other words, the foam strip is not needed in warmer climates like Florida.
They are also good for capturing insects or small pebbles.
The Regal manual recommends the standard air filter, but the previous owner must have changed it out.
This is the cold climate version air filter:
Air Filter - Cold Weather
Cold Weather vs Regular Air Filter
