Jim Sparr
- Oct 8, 2023
- 2003 Buick Le Sabre, 1986 Buick Regal
I am the OP regards the OBD II code no. P0446 on my 'new to me' 2003. I think I may have found the cause and the solution of this code. I am in the middle of flushing and replacing the old leaking radiator, the thermostat, and both upper and lower radiator hoses. I found a broken plastic vacuum line. If you will look at BGFM post no. 9 above on this topic, you will see a great photo of the entire device now known as GM part no. 24506671 which is a combination of a purge valve, MAP sensor, and a fuel pressure regulator. Please note the small plastic line that starts just to the right of center with a 'L ' shaped 'sock' connection and goes via a thin plastic line to the large round connection on the far right end. I found the 'thin plastic line' was cracked where it entered into the 'large round connection on the right end'. Solution: I went to my friendly auto parts store and bought a Dorman part no. 47430 which is an assortment of 4 different vacuum hose connectors in 4 diff. sizes. One size fitted the broken hose and was a perfect fit. Cost of these four connectors was $6.99 plus tax .
Since I am in the middle of replacing the radiator and associated parts, I am not able to drive it right now to see if the code P0446 goes away. I have already purchased the combo part above from Rock Auto. If this small connector solves this problem, I will replace it with the new combo harness of GM part no. 24506671--cost =$19.88. Once I have the new rad. installed and drive it, I will let you know if this simple vacuum leak fix does or doesn't solve this P 0446 problem. In the meantime, I recommend carrying the four piece vacuum hose connectors in the Glove box. Just in case.
