HotZ28
Full Member Since 2005
- Jul 1, 2005
- SE
- 1996 Roadmaster Limited Collectors Edition 58k - 1996 PAU 2019 Regal GS
Great info on this thread. Since I'm not sure what series I have ('93 PAU) like I or II, I may need to check out that elbow, for a car this old.
I suppose if the LIM gasket etc should need fixing, the elbow would need replacing also ??
The 1993 Series I engine does not use the plastic elbow(s) mentioned (shown) in this thread. However, it did come with a plastic threaded hose nipple with an attached rubber hose, which were also problematic.
The replacement metal hose fitting for the Series I engine, can be found at most national part stores in several brands, like Dorman, Help, or Motormite and comes with 5/8" hose x 1"-14 thread. All three of these aftermarket fittings use the same Part #56359 and are available for less than 5 bucks. Of course, if you prefer, most GM dealers would have a replacement metal fitting, Part #25535749 for 15-18 bucks. Keep in mind; this fitting is only for the VIN-L 3800 engine and not for the 96 up VIN-K 3800 Series II. The VIN-L engine came installed in Buick, Olds and Pontiac, in various body platforms.
For removal of the fitting, (if you don’t have a large thread extractor), you can use a flat chisel about the same size as the I.D. of the hose nipple. The cutting end of the chisel is tapered and should go up into the threaded piece about 1/2 in. You will need to bump it in with a hammer far enough, to get a grip on the fitting. Once the chisel is snug, use a crescent wrench to turn the chisel “counterclockwise” and that will loosen the fitting. (It should start coming out). If the chisel slips on the first try, tap it in a little further, then try again.
In addition, you have several options for the bypass hose; Goodyear Part # 63043, Kelly Springfield Part # S-3041, DAYCO Part # 71624, GATES Part # 18801 {5/8" x 7 1/2" Cut to fit) Price range on the bypass hose ranges between 6 and 15 bucks, depending on brand selected. Replacing the hose clamps is optional, if not damaged.
Metal fitting:
Hose:
