Wilburnwalker
- Jul 29, 2014
- Buick
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Does it overheat?My lacrosse a/c works great while car is moving. The cooling fans are not coming on while idling at a stop. I changed the relay and checked cooling fan fuses. They work sometimes but sometimes come on intermittently. How can I trouble shoot this. No codes show on scanner.
Thanks.
The car is not running hot. It is somehow connected with the A/C switch turning the fans on. Should always come on when A/C is on, right? Relay had a black burned spot on it so I bought a new one and replaced it. Still doing it.Maybe check the wiring to the fan for any damage. Inspect the connectors for damage. Inspect the contacts at the fuses & relays too.
Failing electric fans may not turn freely. They may also work intermittently where a few gentle taps or assistance to get spinning gets them going. Car fans are an easy way to lose fingers so you really don't want to be putting your hand near the fan with the battery connected.
Some fans can turn on anytime, even with the car off and key out of the ignition. Use extreme caution.
Oh, the AC condenser fan is really useful in traffic and city driving, but once the car is moving, fan becomes less critical. Incidentially, the AC fan may provide some airflow to the engine and transmission coolers too so you want that working ASAP with these temperatures.
Yes the compressor is running all the time the A/C switch is on but when the fans are not running no air is flowing through the condensing coil. I turned the A/C switch off a few seconds and turned it back on this morning and it started cooling. The fans had come on. Since it is intermittent I thought the relay was sticking but the new relay did not help.Is the compressor running when the fans aren't running.
Not sure if you have a real problem or the compressor isnt running at times causing the fan not to run.
On some GM cars, the AC compressor does not always turn on the related fan and there may be a delay in any case. I don't know about the LaCrosse.The car is not running hot. It is somehow connected with the A/C switch turning the fans on. Should always come on when A/C is on, right? Relay had a black burned spot on it so I bought a new one and replaced it. Still doing it.
When the A/C is cooling what is the temperature of the air coming out of the vents?No codes on the scanner so I guess that’s the only choice I have.
Yes, as long as the pressure switch is working & the pressure is above 185 psi, which is normal with a fully charged system. The low speed fan will only turn ON, if the PCM is getting the correct info from the pressure switch. Do you have 12v @ the fan with the AC on?Ok. Question: Am I right in assuming that the cooling fans should be on when the a/c is on and the engine is cold and idling?
Since the problem is intermittent and sometimes works if you turn OFF the AC and back ON again & the fan's work would indicate to me that there is a bad connection in the relay socket.I just went out and started the car. Cold engine. Compressor running but no voltage at fan. Waited and let it set running and the fans both came on after about 5 minutes. Once they came on it got cold inside. I have changed the pressure switch on the a/c line and the coolant temp sensor. I have changed the relay and checked fuses. Could over charging cause this?
Possibly the pins connecting to the fuse are loose but it doesn't seem likely unless it's been replaced an exorbitant number of times for some reason.Yes, I switched two that were identical in the beginning and it didn’t help but since one looked burned, I bought a new AC Delco and replaced the burned one. ????
