DIY Guide: How to Swap Plastic Intake Gaskets for Aluminum (3800 Series II Fix)
Anthony Cipriano
Been around...
The "Achilles Heel" of the 3800: If you drive a Regal, LeSabre, or Park Avenue equipped with the legendary 3.8L Series II (L36), you have one of the best engines ever made - with one fatal flaw. The factory installed lower intake manifold (LIM) gaskets used a plastic carrier that is incompatible with long-term exposure to Dex-Cool and heat cycles.
The failure mode is predictable: The plastic degrades and cracks near the coolant ports. This allows coolant to mix with your oil (turning it into a "chocolate milkshake") or leak internally, potentially causing a hydro-lock.
The Permanent Upgrade: This isn't just a repair; it's an update. The aftermarket solved this problem by releasing aluminum-framed gaskets. Once you swap these in, you eliminate the engine's only major weak point.
The Parts Checklist:
The "Problem Solver" Gaskets: Fel-Pro Part # MS 98014 T. (Ensure you get the "T" suffix version. These feature the steel core construction that won't degrade like the factory nylon).
Upper Intake Plenum Kit: Dorman Part # 615-180. (The original upper plenum often warps from the heat of the EGR stovepipe. This upgraded kit includes a reduced-diameter metal sleeve to shield the plastic from melting).
Heater Hose Elbows: Dorman Part # 47065HP. (DO NOT reuse the old plastic elbows - they become brittle and will snap inside the tensioner assembly. These aluminum replacements are a "install and forget" upgrade).
Valve Cover Gaskets: Fel-Pro Part # VS 50080 R. (Since the valve covers must come off to access the intake bolts, it's smart money to reseal them now).
The Strategy (Overview): (Note: This overview highlights the critical steps. Always refer to your specific service manual for safety procedures).
Fluid Management: Drain the radiator completely. The goal is to lower the coolant level below the intake ports so you don't flood the lifter valley when you pop the manifold seals.
Access & Removal: The alternator, tensioner assembly, and fuel rail must be moved aside.
The Stovepipe Check: When you pull the upper plenum, inspect the EGR tube area. If the plastic around the tube is deformed, you must use the Dorman kit listed above to ensure a proper seal.
Lifting the Lower Intake: Remove the bolts and lift the manifold straight up to avoid knocking debris into the lifter valley.
Surface Prep (Critical): This is where the battle is won or lost. The mating surfaces on the cylinder heads must be surgically clean. Use a plastic scraper and shop vac to remove old gasket material without gouging the aluminum heads.
The RTV Seal: The rubber end-seals (the "U" shaped gaskets) need a dab of RTV silicone in the four corners where they meet the cylinder heads to prevent oil leaks.
Gasket Installation: Install the new aluminum-framed gaskets dry.
The Tightening Sequence: Precision is key here. Overtightening will crack the manifold. Follow a spiral pattern, starting from the center bolts and alternating outward. Target 11 ft-lbs (132 in-lbs). Use an inch-pound torque wrench if possible for accuracy.
Elbow Installation: Lubricate the O-rings on the new aluminum elbows with clean coolant. They should press in firmly but smoothly.
Project Budget: ~$150 - $200 for the complete parts list. Estimated Time: Plan for a full Saturday (4-6 hours) if this is your first time.
Have you upgraded to the metal gaskets yet? Share your installation photos or "war stories" below!
My 2004 PA has about 206K miles. Oil is going "somewhere" but not puddling. The valve cover and intake gaskets will be replaced. Since the valve covers and intake manifold are plastic, should they be replaced too? Are there aluminum valve covers? Thanks for your post.
The valve covers are a composite plastic and don't have to be replaced. You just replace the valve cover gaskets like in most other cars.
Thanks. I will replace four gaskets (VC and the upper and lower intake). This should keep me on the road for a while.
