- Mar 28, 2005
The "Achilles Heel" of the 3800: If you drive a Regal, LeSabre, or Park Avenue equipped with the legendary 3.8L Series II (L36), you have one of the best engines ever made - with one fatal flaw. The factory installed lower intake manifold (LIM) gaskets used a plastic carrier that is incompatible with long-term exposure to Dex-Cool and heat cycles.
The failure mode is predictable: The plastic degrades and cracks near the coolant ports. This allows coolant to mix with your oil (turning it into a "chocolate milkshake") or leak internally, potentially causing a hydro-lock.
The Permanent Upgrade: This isn't just a repair; it's an update. The aftermarket solved this problem by releasing aluminum-framed gaskets. Once you swap these in, you eliminate the engine's only major weak point.
The Parts Checklist:
The "Problem Solver" Gaskets: Fel-Pro Part # MS 98014 T. (Ensure you get the "T" suffix version. These feature the steel core construction that won't degrade like the factory nylon).
Upper Intake Plenum Kit: Dorman Part # 615-180. (The original upper plenum often warps from the heat of the EGR stovepipe. This upgraded kit includes a reduced-diameter metal sleeve to shield the plastic from melting).
Heater Hose Elbows: Dorman Part # 47065HP. (DO NOT reuse the old plastic elbows - they become brittle and will snap inside the tensioner assembly. These aluminum replacements are a "install and forget" upgrade).
Valve Cover Gaskets: Fel-Pro Part # VS 50080 R. (Since the valve covers must come off to access the intake bolts, it's smart money to reseal them now).
The Strategy (Overview): (Note: This overview highlights the critical steps. Always refer to your specific service manual for safety procedures).
Fluid Management: Drain the radiator completely. The goal is to lower the coolant level below the intake ports so you don't flood the lifter valley when you pop the manifold seals.
Access & Removal: The alternator, tensioner assembly, and fuel rail must be moved aside.
The Stovepipe Check: When you pull the upper plenum, inspect the EGR tube area. If the plastic around the tube is deformed, you must use the Dorman kit listed above to ensure a proper seal.
Lifting the Lower Intake: Remove the bolts and lift the manifold straight up to avoid knocking debris into the lifter valley.
Surface Prep (Critical): This is where the battle is won or lost. The mating surfaces on the cylinder heads must be surgically clean. Use a plastic scraper and shop vac to remove old gasket material without gouging the aluminum heads.
The RTV Seal: The rubber end-seals (the "U" shaped gaskets) need a dab of RTV silicone in the four corners where they meet the cylinder heads to prevent oil leaks.
Gasket Installation: Install the new aluminum-framed gaskets dry.
The Tightening Sequence: Precision is key here. Overtightening will crack the manifold. Follow a spiral pattern, starting from the center bolts and alternating outward. Target 11 ft-lbs (132 in-lbs). Use an inch-pound torque wrench if possible for accuracy.
Elbow Installation: Lubricate the O-rings on the new aluminum elbows with clean coolant. They should press in firmly but smoothly.
Project Budget: ~$150 - $200 for the complete parts list. Estimated Time: Plan for a full Saturday (4-6 hours) if this is your first time.
Have you upgraded to the metal gaskets yet? Share your installation photos or "war stories" below!
