Driver window
Bingo
Verano
I have a 2014 Verano with a power window problem that has me stumped. When the car is started I get the message “Open, then Close Driver Window”. The driver window won’t do anything, there is no relay click, and I had the computer scanned which showed the input is not being triggered. I checked the fuses that I know of and also replaced the entire switch module on the door with the same results. All 3 other windows work correctly from any switch, but the driver window does nothing.
Any ideas to check next?
Thanks!
Pinched wire where they go through the door into the body?
I didn’t see anything the first time I dug into the hinge area, but I’ll check wires there again. Is there a fuse specific to this window control?
