misterRollsRoycer
Contributing Member
- Feb 9, 2012
- Buick
Just replaced wheel hub assembly unit on 98 lesabre. Now car doesn't start. Dead battery. Drained from what I think is a short. Plugged in ABS sensor and put car in neutral to turn wheel to finish setting in the 3 torx bit bolts to knuckle. When engaged ignition to ACC position, noticed sequential flashing of dash lights and lights of buttons next to radio- vent, AC, heater, etc.. Everything started lighting up like a christmas tree. Finished with bolts, turned key to off position. Disconnected neg. batt. wire thinking would reset everything, stuff would work itself out. DID NOT. When wheel and everything back on tried to turn over ignition to start engine and flickering came back along with clicking. Now I thought starter was bad. Tried again. Then chiming sound came along with everything. Followed chiming to headlamp, sentinel etc. module at floorboard below stereo. Pushed "sentinel light" button on driver's side door, turned off chime sound. Clicking sound remained on third and fourth try. Eventually went away, headlights grew dimmer and power just completely drained out of battery. Have no idea what happened. Guy at Auto Zone thinks I fouled up ECM perhaps because didn't disconnect battery cable before doing hub assembly job. Had done the job before w/ battery intact and not had a problem.
Am not sure what is going on. Will check all fuses and try a jump on battery too. And will use DMM to see if voltage appears while battery out of loop showing that there is a short. Any suggestions?
