G
G-301448
_it sounds like a cam sensorFirst time post so here goes, I‘ve driven my 2003 LeSabre Custom(87k and 3800 engine) three months without any engine trouble. About a month ago the check engine light came on and coded P0442 on AutoZone tester. I didn’t address it immediately bc I read it was a minor and common problem that ”typically doesn’t effect the engine’s performance“. I got in it 10 days ago to go to work and it started right up but then began to run terribly rough as though it was missing or getting too much/little gas. I thought it would be fine once I got it going a block or so and it actually got worse, bucking and stalling and eventually died. I got it off to the curb but couldn’t get it to start. I was late for work so left it there until I got home about 10 hours later. i got it to start but had to floor it and feather the pedal to keep it running, bucking, coughing and choking. I left it sit for about an hour, changed clothes and checked for spark on each of the plug posts by removing the wire and every one had spark BUT two of the six post had a little white corrosion on them and the wire. Got that removed and the car started right up without issue just like it always did. Took it for a short test drive and that night and the next mornin......it was fine.
PROBLEM NOT SOLVED though! Took it to run a short errand, about 10 minutes, and it wouldn’t start after I got back in the car about 20 minutes later. I left it overnight and it started the next morning as though nothing ever happened.
It’s sitting in my garage and I’m scratching my head.
I don’t own any diagnostic equipment but it sounds like that would be the next step. I can start changing parts but have no idea where to start... is it fuel or spark related?
thanks for your patience!
