tommybuoy
- Apr 1, 2022
- LaCrosse, LeSabre
My 2008 lacrosse heater malfunctions. Heat will drift out of the vents with the fan on low but on high it blows cold. Thermostat is working properly and coolant temperature is at *215°, the AC works fine. What is the most likely culprit? Mechanics in the shop where I work are baffled.
*Will double check this number but the mechanic says is in the proper range.
