sickfleming
- May 4, 2014
- Mount Vernon AR
- Buick Century
Ok. This is for my 1994 Buick Century 3.1 145k miles. After looking through the forums, it seems that I can't find any info on this. My temp light is coming on. It flickers on and off very rapidly as I drive. The gauge itself is fine, although when idling the other morning it shot all the way till the red zone, plus the heater wouldn't work. I shut the car off immediately and turned it back on moving the heat on and off switch from side to side, then the heater finally came on and the gauge quickly returned to normal, between the quarter and halfway mark. I popped the hood and felt the engine. It wasn't very hot. I'd only been driving it for around 20 minutes. Anyway, I replaced the thermostat, coolant temperature sensor (not the pigtail) and gave the system a flush and added new coolant. It still comes on. I do NOT use dexcool. That was for '95 or '96 onward. The original owner kept putting water in the system so do you think it could be corrosion? Or is it transmission related? Other than that, the car doesn't do anything out of the ordinary. Thanks!
