Kurts53Buick
- Aug 7, 2025
- 1953 Buick Special 41D 4 door sedan
Hi group. I have 1953 Buick Special 41D 4 door sedan tourback. The person who owned it before me and sadly died years ago put a Chevy small block 350 with TH350 trans and Ford 9 inch Rear End. It also has power steering (with rack and pinion) and 4 wheel disc brakes. It sat in storage for years after the guy died and the person I bought it from knew nothing about it...
It seems the upper and lower control arms are stock though. And I can see where the sway bar was cut off (a piece is still in the mount holder). And there are NO front shocks at all in the front. I guess the upper wishbone thing has a shock type system in it?... Anyway. The car is very bouncy bouncy and id like to put a 1.25" upgraded sway bar in the front with poly bushings... I don't have an old on to measure and I can't find one by googling it.
Does anybody know what front sway bar "upgraded size" set up will work for my car? I circled in red where the sway bar was cut off... (Unless I'm confusing it with something else, some other suspension bar?)....
Thank you.
Kurt
Thank you.
Kurt
