Need help with front sway bar (mines missing). 53 Buick Special 41D 4 door sedan
Kurts53Buick
1953 Buick Special 41D 4 door sedan
Hi group. I have 1953 Buick Special 41D 4 door sedan tourback. The person who owned it before me and sadly died years ago put a Chevy small block 350 with TH350 trans and Ford 9 inch Rear End. It also has power steering (with rack and pinion) and 4 wheel disc brakes. It sat in storage for years after the guy died and the person I bought it from knew nothing about it...
It seems the upper and lower control arms are stock though. And I can see where the sway bar was cut off (a piece is still in the mount holder). And there are NO front shocks at all in the front. I guess the upper wishbone thing has a shock type system in it?... Anyway. The car is very bouncy bouncy and id like to put a 1.25" upgraded sway bar in the front with poly bushings... I don't have an old on to measure and I can't find one by googling it.
Does anybody know what front sway bar "upgraded size" set up will work for my car? I circled in red where the sway bar was cut off... (Unless I'm confusing it with something else, some other suspension bar?)....
Thank you.
Kurt
Thank you.
Kurt
Sway bar has nothing to do with the car being bouncy. Sway bar is to prevent car from rolling in turns, bouncing is because you have no shocks.
Get a GM Buick service manual for your 53 and use it to check against the vehicle, note this is a 52 but similar to the 53. The manuals are available Google it.
These are the part #'s for the swaybar. It may help you ID one in ads or searches.
Group 7.241 - Shaft, Stabilizer (sway bar) - Front
Part number 1319823 - 1948-52 All and 1953 Special
Part number 1343088 - 1953 Super and Roadmaster
Part number 1162022 - 1954-56 All
Aren't the tops of the control arms supposed to be the "shocks"? The wishbone whatevers... I dont remember. I know I need to weld on shock tabs and mount some shocks. But there is absolutely no place that is there for them... And there is something cut off ... What is cut off that I circled in the picture?
I do appreciate you taking the time to help and share your knowledge. I understand shocks stop the bounciness.
The upper control arm has a hydraulic "knee action" double acting shock absorber attached there.
These are rebuild-able, and there are vendors in Hemmings who advertise that service.
"Addco" sells aftermarket sway bars for many vehicles, and may be worth a call to talk about yours.
See the diagram, your photos show this type of shock on the vehicle.
Thank you for verifying that those were in fact the factory upper hydraulic knee action double acting shock absorbers.
I thought that is what I read. Are those (when in good working order, a good ride)? Also given that the car has a small block Chevy 350 and TH350 transmission and Ford 9 inch Rear End... Im not sure if those are a heavier load for the vehicle and the knee action shock just can't keep up with all of it.
And with all of that information, I am not against it being modified more and plan to put air suspension in it later down the road. I would think putting tube shocks on it would be cheaper.....
I'll check on the price. Thank you for the information and taking the time to help me.
