Franki
- Nov 4, 2011
- Santa Barbara County, CA
- 2011 Buick LaCrosse CXL
Hi All,
My 2011 LaCross CXL has been amazingly flawless - that is, until we were due to go on a road trip. Here's the TV news version: about three days before our departure I entered four destinations into the nav, without the motor running. The car sat in the garage until the morning we were to leave. We packed up, headed out about two blocks when I noticed the speedo, tach and audio/nav systems were dead. Nada. The car was running fine, but there were a lot of warning lights on the dash. We didn't know at what point the car would completely die so we pulled back into the garage (head in - a mistake) and took my wife's dependable, reliable, steady Toyota RAV4.
When we returned nine days later, the Buick was dead. Nothing. Called our local dealer, got it towed. Discovered you can't use a screwdriver in a slot to get the car out of park when there is no power. There is a cable that must be disconnected UNDER the car. Car turned around in the garage on dollies by tow truck driver with greasy hands.
The 'technician' at the dealer looked and looked for three days, without success. He could not find the problem, only saying 'the computers are not communicating to each other.' They must be married, said I. Dealer tried to blame the problem on a trailer hitch and wiring I had installed, so the wiring was removed.
Battery fully charged, I pick up the car and it was running just fine - until last Friday.
I think I may have left on a dome light. When I went to start the car it was dead. I mean dead. Nothing.
Called the dealer. Called a tow truck. Jumping the battery got a re-boot, some lights worked, but it would not run the starter. Car towed to dealer (again,after being turned around in the garage on dollies!). Yes, I will probably back in from now on.
Monday evening received voicemail from service mgr: still trying to find cause of problem, "car is not communicating with itself. Still investigating. Supposed to be communicating data, not voltage. Checking the combs (?) where the actual wires connect."
The tech has been on the phone with GMC experts.
So....that's the TV news version. Imagine if I had written a newspaper version.
Any thoughts? Oh, did search the forums for this problem. I also went back several pages to look for a similar subject heading.
Car is at 19,300 miles and still under warranty.
It's been great otherwise!
