Itchigo
- Jul 21, 2025
- 1999 Buick LeSabre
Hi all, I'm new. I have a 1999 LeSabre that only blows air out of the defroster vents. I replaced the actuator behind the passenger glovebox (really tight to get to). I don't seem to be getting any movement out of it, so I don't know if I have another problem. Is there a vacuum hose that operates this as well? I also replaced the blower on the firewall a few years ago. The center dash display works as if the actuator is working, in other words it shows it's on vent when I'm getting air out of the defrost instead. I'm pretty mechanically inclined, so if you direct me to look at something I can probably handle it on my own.
Edit: After revisiting this a little while ago, I get air from the defroster- always. I seem to be able to turn off the floor vents via the center dash buttons. But nothing out of the vents. There HAS to be a vacuum hose somewhere...
I want to fix the A/C which would require a lot of work, but I don't want to even start until I figure this problem out.
