3800series2
- Dec 18, 2020
- 2003 Lesabre Limited
Our 2003 LeSabre that I was checking in on today. Wow. Removed the rocker covers. The driver side rear dog leg is SHOT. The hole is about big enough to fit hand in. The under body is still relatively clean. Got all the loose rust off, then hit it with rusty metal primer followed by undercoating. I plan the fill it likely with foam of some sort just to block it from filling with road debris. Hopefully that will extend the life a few years.
added a photo of the inside of the front right fender after removing that soft splash guard material. Does anyone know if that is needed? Seems as though it just harbors moisture.
anyway, thought some might be able to relate and find this interesting.
