94 Roadie limited
- Feb 13, 2025
- 1994 Roadmaster Limited
Hello all and I need some help. 1994 RML, driver's door. I replaced the motor due to very slow operation. Well, that was not the problem. The window is "tight" about 4-5 inches from the door sill, as it goes up. If I manually help it up, it goes up but doesn't align correctly. The window can be moved almost a half an inch to it's proper location. (Someone has been in there before) I can't align it correctly. I lubricated the weather stripping and channel (desert car).
I read the manual, but I am stumped. I'm suspicious it's a bad or warped regulator. Very open to ideas..
