AshleyQuick
- Aug 18, 2015
- Virginia
- 2003 Buick LeSabre
If you're familiar with this install, you'll recall that an obstacle is that the camber bolts don't quite have enough clearance to pull out toward the front, thus the need to lower the subframe a bit to provide that clearance. In researching, I've read a few have been successful in removing these camber bolts by simply supporting the subframe and loosening the two 18mm rear subframe bolts just enough to provide the space (looking under there today, it needs 3/4 to an inch).
Yet the method in the following video has you remove a shield, a couple other things AND lower the exhaust system. While I'm sure this method is relatively easy/practical if you have a garage and a lift, it's arguably not so much for the average DIY mechanic at home in their driveway like me
So I guess my questions are have you tried the first method? Would you? I'm inclined to give this a shot and of course doing so while being extremely careful to lower just enough while supporting with the pump jack. I bought these Moogs from RA and I'm anxious to install...and to not pay anyone 🙂
