jamesroodney
- May 27, 2015
- Buick
I just changed out the coil spring on my 03 Rendezvous and everything went decently but now getting the lower arm of the shock absorber back onto the control arm is causing me some trouble, as the rubber bushing refuses to slide all the way onto the bolt and squishes out through the opening in the lower arm of the shock. Is there a trick to this, like having the car on the ground (as opposed to on the stand). I can get the rubber on the bolt by itself too but then when I try to slide the shock over it it gets hung up again and pushes right to the end of the bolt (and deforms too much to fit into the opening anymore...
Any tips would be appreciated, thanks!
