Regal GS, runs great fine for a short period then enters reduced power mode. Codes came up, any help?
grandpags
2012 Regal GS 6mt
Hey guys and gals, first time poster here.
A little backstory on the car may help so here goes. I have a 2012 gs, full bolt on minus intercooler. Car has been parked since last fall as the canadian winters are too sketch for a fwd car of this power.
car makes great power when running good. Last summer after a night of fun i found out i had a bad turbo seal but now after replacement it ran alright. Today i go to start it and it high idles for about 30n seconds then began to idle rough and flash a reduced power mode.
Codes are P2176 (minimum throttle position not learned), u0109 (lost communication with fuel pump control module) and P2101 (control module throttle actuator position performance/throttle actuator position performance)
Should I take it to the dealer do yall have any ideas? thanks
Unless you are capable of diagnosing those codes your only choice is a dealer of qualified shop.
