Kavik_Whitescar
- Jun 8, 2014
- Louisville, Ky
- Buick Lesabre (95)
Howdy all, my 95 Lesabre (custom) has been running real rough the last two weeks, I have a theory that when I got the oil changed they didnt tighten something properly and this is why.
The day after the change it sounded real odd and was running rough but its old and Ive had issues like this before where the motor mounts just needed to be tightend, so I took it home opened it up and they were soild. Over the next week things got a little crazy, while idle the entire front end of the car vibrates, visably. I can watch the dash, steering wheel and everything shake. It was having serious issue taking off (fixed with a new muffler and spark plug replacement I think) but never stalling out or dying.
While driving it will randomly start shaking real bad until I release the gas, I cant bring it over 60 right now at all without it shaking (what sounds like the engine but again the whole front end shakes uncontrollably) Thursday it sounded like the Catalytic was blocked up, a type writer kinda sound when driving and worse when idle so I took it to a local shop to be tested. When I took it to be tested the guys said it was fine but my muffler had a hole in it and needed to be fixed (which i was fine with i had a scrape with a speed bump)
It sounded great, now here is where I am at.
It sounded bad, like a whine of metal on metal for 40 yards, when i could pull off the noise stopped but thin whispy white smoke came from the passenger side of the hood. My girlfriend said the door felt warm and so I kicked the heat on and nursed her back home. The smoke and shaking started up only when idle. The next day, my dad and I replaced the spark plugs hoping that it would help fix the running rough issue and the air filter. I noticed my engine was covered in oil (that wasnt there two weeks ago) and gunk, and thats how I came to the Vavlvoline boys didnt do something right. Im taking it in tmrw to be topped off and see if they maybe didnt seal something right.
Any clues, tips or anything would be appreciated. I can give more info as needed and will be checking periodically for the next 7ish hours (im at work)
