Sounds like a good reason. 🙂The reason I want to change the valve cover gasket is that I see some oil around the valve cover.
I can't tell whether it is all oil or a mixture of oil and coolant. I think I lost quite a bit of coolant, maybe a gallon over a period of several months. I just added more coolant and will see how it goes. And by the way, how do I go by replacing the lower intake gasket, and is it a big job?
Thanks,
Daniel
Thanks for the info. I wish I know of a reliable mechanic here in Chattanooga TN to do the job for me. By the way, where do you buy the parts.
Thanks,
Daniel
If you're still around could you send me that PDF as well I'm about to do upper and lowerDan, send me a PM with your email address, and I'll send you a pdf file along with pics that I created when I did the upper and lower intakes on my 2000 LeSabre. It will have part numbers, etc. and other useful info.
