Speedo, tacho, and blinkers dead!
tysperry
I have a 94 Buick LeSabre limited.
Suddenly, out of the blue, the speedometer, tachometer, and the blinkers stopped working. I,ve checked the fuses in the engine compartment, all look ok.
I did recentley replace a broken spring on one of my valve lifters. I doubt its related but who knows.
Any direction you can give me will be greatly appreciated.
Thanks,
Ty
I had that problem but my problem went away. You probably need a guage cluster. Do a google search and you will find them.
I took out my gauge cluster and had it bench tested. Everything check out just fine.
After I plugged it back in, the speedometer, tachometer, and blinkers still don't work.
Any Ideas???
I pulled the gauge cluster and had it bench tested. Everything worked just fine including the signal lights.
After reinstalling in it back into the Buick. Still no speedometer, tachometer, or turn signals. Any thoughts????
