Is the needle the only thing not lit up? the backlighting all appears consistent and properly lights up? If I had to guess the needles are fiber optic with a bulb behind them that can be replaced.Is it right that you can't replace the light of the speedometer needle and the entire instrument cluster needs to be replaced?
Again I would think it’s a fiber optic which gets its source from a light bulb but I could be wrongOnly the speedo meter needle is not lit up. I always figured that it was backlit or the needles where some glow in the dark type thing, but now I notice they have a definite hot spot in the middle of the needle. The back light is done with 7 PC168's, I haven't opened the instrument cluster, but I'm afraid it looks like the needles have a little light in them.
