skypilot_1
- Apr 2, 2020
- 19 TourX Essence
Anyone know what the largest 18" tire size will fit on TourX OEM suspension. Like a little more ground clearance. Thank
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Good reference @ TireSize.com - click on "Alternate Sizes" & there's a guide with measurements displayed.Anyone know what the largest 18" tire size will fit on TourX OEM suspension. Like a little more ground clearance. Thank
Thanks, but not the point. I know what the tire sizes are........just don't know what the largest tire that will fit is. OEM is 27.3 inches.Good reference @ TireSize.com - click on "Alternate Sizes" & there's a guide with measurements displayed.
235/55x18 increases diameter about 1" and that is a 3.3% increaseThanks, but not the point. I know what the tire sizes are........just don't know what the largest tire that will fit is. OEM is 27.3 inches.
TireSize FAQ:Thanks, but not the point. I know what the tire sizes are........just don't know what the largest tire that will fit is. OEM is 27.3 inches.
Generally, it is recommended to not exceed a 3% difference when changing from the OEM size on a non-modified vehicle. A green row means that the alternate tire diameter matches the calculated tire diameter. However it does not mean that the tire will definitely work for your application, the width of the tire still needs to be accounted for.
215/65/17 winters. Comparison is with 255/45/18's.
i'm starting to look for a set of steel rims, as we may have to start running our TourX in the salt next winter
Refurbished Dodge Magnum wheels from eBay. They are a 17x7, 22mm offset. So the outer edge lands about 6mm further out than the stockers. Unfortunately, the fronts just barely kiss the caliper, so I had to add a 3mm spacer for breathing room. 3 winters, no issues.i'm starting to look for a set of steel rims, as we may have to start running our TourX in the salt next winter
Do you remember where yours came from or brand or source?
Thanks
The TourX stock tire size is 235/50R18? That’s 14.5mm taller than the 245/45R18 on my car. I guess maybe the TourX, with the extra weight, could benefit from taller tires.Going from the stock 235/50/18 to a 235/55/18 will put you a full inch taller than stock
If I had to guess, I would think GM threw the slightly taller tire on the TourX for the same reason they put cladding on it - to appeal to the out-doorsy crowd.The TourX stock tire size is 235/50R18? That’s 14.5mm taller than the 245/45R18 on my car. I guess maybe the TourX, with the extra weight, could benefit from taller tires.
255/45/18 is about 1/4" shorter than a 235/50/18. So 1/8" less sidewall. If you really want more sidewall, going down to a 17" rim will net the largest gain.I was thinking about 255 45 18’s, until I hit some serious potholes. They’re a great size match, but I’d worry about rim damage. Especially with no spare….
