Reverse Band Servo is the ltitle circle on the top of the transmission, inline with the area you are looking at (the end with the hole for the axle shaft) Those are known to leak
#04-07-30-028A: 4T65-E AUTOMATIC TRANSMISSION FLUID LEAK FROM REVERSE SERVO COVER (REPLACE REVERSE SERVO COVER SEAL) (JAN 12, 2006)
Models:
2005 and Prior Cars and Light Duty Trucks
with Automatic Transmission 4T65-E (RPOs MN3, MN7, M15, M76)
This bulletin is being revised to announce an improved reverse servo cover seal is available from GMSPO and to advise technicians that it is no longer necessary to replace the reverse servo cover when replacing the seal. The 2005 model year vehicles are also being added.
Condition
Some customers may comment on a fluid leak under the vehicle.
A transmission fluid leak may be noted during the Predelivery Inspection (PDI).
Cause
A possible cause of a transmission fluid leak usually only during cold ambient temperatures below –6.7° C (20° F) may be the reverse servo cover seal. The reverse servo cover seal may shrink in cold ambient temperatures causing a transmission fluid leak.
Correction
Follow the diagnosis and repair procedure below to correct this condition.
1. Diagnose the source of the fluid leak. Refer to Fluid Leak Diagnosis, SI Document ID #634313.
2. If the source of the transmission fluid leak is the reverse servo cover, replace the reverse servo cover seal with P/N 24235894. Refer to Reverse Servo Replacement in the appropriate Service Manual.
3. Clean the area around and below the cover.
4. Inspect the transmission fluid level. Refer to Transmission Fluid Checking Procedure in the appropriate Service Manual. |
I would just be sure before doing anything because
"This leak appears to occur at temperatures below 20F
. The exhaust crossover pipe and rear manifold must be removed to make the repair, and thus the repair for this condition will be expensive "
You did the front exhaust log from ZZP right? maybe its time for the crossover and rear if you want to do it all at once
The leak may not be there tho, so take that how you will
You can use a product like AT-205 ATP Automotive AT-205 Re-Seal
