MrBuick (Magnum)
- Dec 11, 2006
- Benton Harbor, MI
- 95 Roadmaster Sedan (3), 94 & 96 Roadmaster Wagon
Did you know that you can access your Engine(and other) trouble codes thru the Climate Control? Did you also know that you can accurately monitor the engine RPM, vehicle speed, coolant temp, and others? If so, good job! If not, look at this! 😉
*Please note, some of this was info copied directly from ISSF.
Instructions for putting ACC in diagnostic mode -
- turn ignition to ON position (or start vehicle)
- press and hold the "temp up" and "OFF" buttons at the same time until the unit does a full segment check.
- Release the buttons.
- Display should read -00... you are now in diagnostic mode
- Using the fan up/down buttons, select desired function from above
- press the "middle" Button. It should be in the top right corner on the CC.
- To Exit the trouble code area, and go back to the -00 display, hit the "Middle" button again.
Have fun!
You will see -00. You can change the funtion(it will say -01, -02, etc) with the fan up, and down buttons. Here is a list of what all the -00 numbers mean.
Here are the most common you will need to know
-00 PCM diagnostics codes
-01 CCM Diagnostic trouble codes
-02 HVAC Diagnostic trouble codes
-03 SIR Diagnostic trouble codes
-04 ABS/TC Diagnostic trouble codes
-06 Engine RPM
-14 Vehicle speed
-24 Coolant Temp (°C) - Reading taken at the Water Pump sensor, This is what the PCM uses to control the fans.
Quoting Scott Mueller:
"B/D-car coolant fans operate under PCM control at the following engine temperatures and A/C system pressures:
Fan………………Mode……Temps………………A/C Pressure
Primary (RH)…ON…… 109°C / 229°F……189 psi
Primary (RH)…OFF……105°C / 221°F……150 psi
2ndary (LH)……ON…… 112°C / 234°F……240 psi
2ndary (LH)……OFF……108°C / 227°F……210 psi
Additionally, the PCM will turn off the fans at higher vehicle speeds (above 48 MPH I believe), since running fans can actually impede airflow through the radiator at high speed.
Each fan also has a minimum running time. Once activated, the primary fan will run for a minimum of 50 seconds, and the secondary fan for a minimum of 26 seconds.
Finally, certain Diagnostic Trouble Codes (DTCs) may cause the PCM to turn on one or both fans."
Diagnostic Pointers and Parameters
No. Description Range Default Value Units
-00 PCM System Diagnostic Trouble Codes ...............................................
-01 CCM System Diagnostic Trouble Codes ...............................................
-02 ACAC (HVAC) System Diagnostic Trouble Codes .......................................
-03 SIRSystem Diagnostic Trouble Codes ................................................
-04 ABS/TC System Diagnostic Trouble Codes ............................................
-05 Program number .......................... 0-255 ....... n/a ............. Counts
-07 Command Blower Motor Speed .............. 0-128 ....... n/a ............. Counts
-14 Vehicle speed ........................... 0-199 ....... n/a ................ MPH
-15 HVAC Learn Mode (Temp Cal) .............. -5 to +5 F .. 0 F ............ Degrees
-18 Sun Load Sensor ......................... 0-255 ....... n/a ............. Counts
-20 Current Temperature Valve Position ...... 0-255 ....... 240 ............. Counts
-22 Temperature Valve Position (Full Cold) .. 180-250 ..... 180 ............. Counts
-23 Temperature Valve Position (Full Hot) ... 5-60 ........ 60 .............. Counts
-24 Engine Coolant Temperature .............. -40 to 151 .. n/a ............ Celsius
-25 Command Temperature Valve Position ...... 0-255 ....... 128 ............. Counts
-27 Air Delivery Mode ....................... 0-9 ......... n/a ... Code (see below)
-28 Inside Air Temperature Sensor ........... 0-255 ....... n/a ............. Counts
-31 Outside Air Temperature Sensor .......... 0-255 ....... n/a ............. Counts
-37 EEPROM Revision Number .................. 0-0000 ...... n/a ............... Code
This is for 94-96's!!
Have fun!
-06 Engine RPM
-14 Vehicle speed
