Trunk moisture / leak issues solved
nate7799
Lynnwood, WA
1994 Roadmaster sedan
For years I was trying to solve the moisture problem in my Roadmaster sedans trunk . I finally found the source . Where the body joins together behind the rear wheels had gaps from previous damage underneath . The way I found it , I emptied everything out removed the carpet and put a super bright light inside . (I did this in the dark ) I could see the light coming out of the places that had gaps . I used some ac delco body seal first ,which came in a caulking tube, then I got a can of some brushable body seal to mimic the way the factory sealed it when it was made . Finally have a dry trunk ! This method works great if you're having trouble like this and you've tried other suggestions to no avail.
