So I do hear the pump kick on and fuel does come out of the lines going to the fuel rail. As far as the oil sender, are you talking about the sensor that you screw in the motor and then attach the electric harness. If so I replaced that about four months ago with ac Delco original sensor. I looked at that and it seems fine. The thing I did notice now is the oil seems to smell like there is some fuel in it. And when I try to start it now it will sometimes start to act like it's gonna fire up very briefly. And very inconsistent. I've gotten under both sides and don't see anything obvious. Think I'm gonna take fuel rail off and check injectors and go from there. Probably pull upper
intake and again go from there. If I go all the way to the lower
intake will I be able to reset the gaskets if they are in good shape? Not sure what else to do at this point. Can't find any vacuum leaks. But it's getting spark and getting fuel to the rail. So I must have messed something up.
