daleearnhartjrrules
- Jan 9, 2009
i have heard the limiter is set to 109 but im not sure help me out please =]
I hit 125mph last night in my 97 ultraAnyone actually planning to try and go that fast in their Park?
I went 109 and the car made a weird filling and would not go any faster.Anyone actually planning to try and go that fast in their Park?
108*I went 109 and the car made a weird filling and would not go any faster.
127*I hit 125mph last night in my 97 ultra
Unless I am mistaken, I think the factory equipped tires were speed rated "T" (Base) and "H" (Ultra), which would be 118 and 130 mph, respectively.Depends on the stock speed rating tire
108*
127*
GM use of a speed is rooted in a few things potentially
1) If the speed rating of the tires equipped factory, 15, 16, 17 inch wheels are mostly at play for the full size 90s-2000s GM full size cars
I can not go over 109 in 2000 buick park aveI went 109 and the car made a weird filling and would not go any faster.
you cannot go over 108I can not go over 109 in 2000 buick park ave
If they are 118 and 130 my guess its then 1) keep under the tire speed of course 2) probably due to NA while at that high speed, gm wouldnt bother to give calibrations for each and every build, if NA cars and supercharged both got T tires, but one car could go faster, for example, it wouldnt matter unless it had H tires. if that makes sense. Because final drive and the ratios of Hd trans is different Im pretty sureUnless I am mistaken, I think the factory equipped tires were speed rated "T" (Base) and "H" (Ultra), which would be 118 and 130 mph, respectively.
I believe more common nowadays are "V" tires, which would be 149 mph, at least in my region.
I have 2000 ultra tops out at 107, I guess the tires were not rated above that speedUnless I am mistaken, I think the factory equipped tires were speed rated "T" (Base) and "H" (Ultra), which would be 118 and 130 mph, respectively.
I don't understand what is impressive about 120 mph with a supercharged 3.8 liter V6.I had a PCM re-flash on my PAU GTS, which eliminated the 110-mph speed limiter. Top end is now unlimited and ungodly! I have very few safe places to exceed the speed limit, but have buried the 120-mph speedometer to the peg several times in less than 1/2 mile. Of course, this is not a normal, or stock engine!
